Elsydeon
Feb 16, 2023Aspirant
POE++ switch with MAC filtering
I am working with a client to install an outdoor camera system. One of the possible security issues is if the camera were removed, it's ethernet connection could be used to gain access to the net...
ErwinL
Mar 10, 2023NETGEAR Moderator
Hello Elsydeon,
And welcome to the NETGEAR Community! 🙂
Indeed you are correct, nothing was mentioned about MAC filtering for MS108EUP. So for your requirements the next device I would suggest you buy is MS510TXUP, although this device has no MAC filtering mentioned also on the manual but has port security that you can setup for protection. You may check page 375-379 from the link below on how to configure this.
Have a lovely day,
erwin
NETGEAR Team
