CGNYUS's avatar
CGNYUS
Follower
Aug 09, 2018
Poort Overall Perforce
Hello, We just installed a stack of M4300's and are having very poor performace.  I noticed the VLAN interface speed is showing at 10Mbs Half Duplex.  Is this something that can be reconfigured?
Thank You
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi CGNYUS,
    Welcome to our community! :)
    Yes, you can manually force the port speed to 1000M as long as the device connecting to it supports gigabit. Go to Switching > Ports > Port Configuration.
    Here is the manual for reference(page 194).
  • JohnC_V's avatar
    JohnC_V
    CGNYUS,
    I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
