bfowler9024
Jan 17, 2016Aspirant
Port Configuration page on GS752TP doesn't work
I can't apply any port configuration settings, such as a Description, Enable/Disable, or Port Speed. The APPLY button does not activate. Also cannot navigate from this page to other settings unless I reload the browser which takes me back to System Information page.
1 Reply
- DaneANETGEAR Employee Retired
Hello bfowler9024,
Welcome to the community! :)
Let us isolate the problem. Kindly answer the questions below:
a. What browser are you using to access the web-GUI of the GS752TP?
b. Are there any error message/s that came up?
c. Did you try using other browsers like Firefox or Safari to isolate the problem?
d. Did you try using other PC/s or laptop/s?
e. What is the current firmware version of the GS752TP switch?
f. Have you tried to perform a factory reset the GS752TP then reconfigure it from scratch and check if same problem occurs?
I look forward to your response.
DaneA
NETGEAR Community Team
