orpz
Mar 02, 2026Tutor
POST Issues GSM4248UX
Hi, the power on start of self teset on my
GSM4248UX is failing. I power on the switch and it starts with the test. All of the ports in the back of the unit light up for a few seconds. The power L...
orpz
Mar 11, 2026Tutor
After working with Netgear support, they idenfy this to be a hardware issue specifically with the power module.
The switch’s PoE subsystem is failing to initialize at boot. Evidence from the technical logs shows: ⦁ PSE remains OFF and “Get PoE FW Failed” is reported. ⦁ show poe port info all returns only headers (no port table), which occurs when the PoE controller is not up. ⦁ No OS/kernel crash dump is present; system uptime and boot logs are otherwise normal aside from transient driver buffer warnings. ⦁ Thermal and fan readings are normal; PS‑1 and PS‑2 are operational (PS‑3 not powered is non‑blocking).
Just putting out there for anyone facing a similar issue. Keep in mind any warranty for your hardware.
- schumakuMar 12, 2026Guru - Experienced User
Had ever connected the console as suggested earlier?
One would expect these problems as also recorded in the tech logs would become visible.
