orpz
Mar 02, 2026Tutor
POST Issues GSM4248UX
Hi, the power on start of self teset on my
GSM4248UX is failing. I power on the switch and it starts with the test. All of the ports in the back of the unit light up for a few seconds. The power L...
orpz
Mar 13, 2026Tutor
Yes, I did. It extablished console connection but it halted with out any errors or messgeas that meant anything to the support tech.
On another note, be aware that the lastest firware has a bug in the AV UI. When creating new profiles, it doesn't take certain subnet masks address. You will need to log into the main UI and entern your subnet maks under Routing > VLAN.
Thanks.
