G-R's avatar
G-R
Power requirements for APM408C-10000S
Is there a datasheet for a APM408C-10000S stating power and thermal requirements?
Is there a datasheet for a XSM4396K0-10000S stating power and thermal requirements with one APM408C-10000S installed and operating?
  • schumaku's avatar
    schumaku
    The M4300 data sheet says
    * PoE Budget depends on number of PSU and APM port cards per switch. Min values above are guaranteed when 6xAPM408P (48x10G PoE+) plus any combination of 6 other port cards. Max values
    are guaranteed when only 6xAPM408P (48x10G PoE+) per switch, or less. APS600W provides 600W@110V/220VAC; APS1200W delivers 1,050W@110VAC or 1,200W@220VAC per PSU. The system
    consumes 110W, plus 5W per empty slot. APM408C/APM408P consume 38W per port card. APM408F/APM402XL consume 23W per port card.
    P.3 https://www.downloads.netgear.com/files/GDC/datasheet/en/M4300.pdf
    Note: The usage of 10GbE does make a big jump.
    • G-R's avatar
      G-R
      Thanks. Sorry I missed the note at the bottom of the datasheet.
ProSupport for Business
