Budgie2
Aug 14, 2014Aspirant
Problem Setting Management Address on M4100
I am struggling here. I have an internal LAN subnet for private use which is established by DHCP server on a firewall/router port. Beyond the firewall are the routers to the WAN. I thought I could...
Marto731
Budgie,
For a wired PC on your network, do CMD >> Ipconfig.
Can you compare the results with what you have inputted. Check subnet mask, and that default gateway is the same as your Router IP.
Plug out switch. Can you ping the IP in question, and see if some other
device responds.?
Regards, Marto
device responds.?
Regards, Marto
