Budgie2
Aug 14, 2014Aspirant
Problem Setting Management Address on M4100
I am struggling here. I have an internal LAN subnet for private use which is established by DHCP server on a firewall/router port. Beyond the firewall are the routers to the WAN. I thought I could...
Marto731
Aug 15, 2014Aspirant
Budgie,
Can you put connect to the switch on the bench, 1:1, not on network.
http://support.netgear.com/product/M4100-50G%2b%2428GSM7248v2h2%2429
Review install 2 page PDF.
http://www.downloads.netgear.com/files/GDC/M4100/M4100_IGprt%207Nov2012.pdf
There is a paragraph referring to a Unix machine.
Is there any MAC address filtering on your network, that would stop access?
Thanks, Marto
Thanks, Marto
