Budgie2
Aug 14, 2014Aspirant
Problem Setting Management Address on M4100
I am struggling here. I have an internal LAN subnet for private use which is established by DHCP server on a firewall/router port. Beyond the firewall are the routers to the WAN. I thought I could...
Budgie2
Aug 16, 2014Aspirant
Hi Marto,
There is no MAC filtering set up on the lan at present.
The unit is in closet so I shall have to bring it back to workshop in order to use USB port.
Will get round to it asap.
Meanwhile can you think of any reason why I cannot use a fixed address within same subnet as router port?
Seems odd to me but if it is an issue, it means I shall have to set up a "management" subnet, in which case I shall consider putting the management of all my fixed IP devices on it.
Thanks again.
Budgie
Thanks again.
Budgie
