saima24
Jul 22, 2026Aspirant
Problems with Isolating a VLAN
I’m trying to isolate a laptop with the scenario that there may be a possible malware or infection. Currently my major problem is that we’re not getting our expected results. Our goal is that we hav...
schumaku
Jul 22, 2026Guru - Experienced User
Nothing you can reach using a basic VLAN configuration.
saima24 wrote:Currently my major problem is that we’re not getting our expected results.
What switch model (and firmware version) do you have in mind, or trying?
saima24
We are using the M4250 Series and I'm trying to test and see if we can restrict one pc from reaching the printer on a separate VLAN but allowing the other test pc to be able to get to that printer, and we want to accomplish these results with IP or MAC ACL's
- schumakuJul 22, 2026Guru - Experienced User
That's a Managed Switch. Have moved this thread to the more appropriate community section.
He smarter approach (instead of fiddling with ACLs only) would be configuring some Private VLAN -> What are private VLANs and how do they work with my managed switch?
