namrevil71
Nov 15, 2016Guide
Prosafe 8 port switch model GS108v3 firmware issue
I need the orginal factory firmware that came with the GS108v3 8 port switch. The Pro Safe configuration software identifies it as model GS108E* but the model number on the switch itself is GS108v3. ...
- Nov 16, 2016
I was suprised as well and it did have a web management interface which according the specs it shouldnt have. I went and ordered a new GS108e managed switch today to replace it for peace of mind so I am gtg.
Thanks for your help
JohnRo
Nov 15, 2016NETGEAR Employee Retired
Hello namrevil71,
Welcome to the community!
It is quite hard to know what firmware version the switch came with since they are manufactured on different dates. You'll have to match the manufacture date on the date the firmware was released. If you can PM me the serial number of your switch I can look up the correct model number. The ProSafe Plus Configuration Utility may not display the version of the switch, just the model number. I don't see version v1.0.0.6 on the download site, where did you download that version?
Thanks,
namrevil71
Nov 15, 2016Guide
Thanks for the reply. How do I private message you through the forum or do you want me to email you separately? I got the 1.0.0.6 firmware from the Netgear website for model GSS108e as that was what the ProSafe software identified it as. I am surpised that even tried to install it as it is clearly not the model I have. The version of firmware that was on the device prior to that was1.0.0.0 which I assume was the orginal factory installed version.
