namrevil71
Nov 15, 2016Guide
Prosafe 8 port switch model GS108v3 firmware issue
I need the orginal factory firmware that came with the GS108v3 8 port switch. The Pro Safe configuration software identifies it as model GS108E* but the model number on the switch itself is GS108v3. ...
- Nov 16, 2016
I was suprised as well and it did have a web management interface which according the specs it shouldnt have. I went and ordered a new GS108e managed switch today to replace it for peace of mind so I am gtg.
Thanks for your help
namrevil71
Nov 15, 2016Guide
Thanks for the reply. How do I private message you through the forum or do you want me to email you separately? I got the 1.0.0.6 firmware from the Netgear website for model GSS108e as that was what the ProSafe software identified it as. I am surpised that even tried to install it as it is clearly not the model I have. The version of firmware that was on the device prior to that was1.0.0.0 which I assume was the orginal factory installed version.
JohnRo
Nov 15, 2016NETGEAR Employee Retired
Hi namrevil71,
You can click on my avatar and it will take you to my profile, then you'll have the option to send me a private message. I see, GS108v3 and GS108e are two different units. That may be the reason why it was corrupted, does the ProSafe Utility show up firmware 1.0.0.6?
Thnaks,
