_Olivier_
Jan 29, 2016Aspirant
ProSAFE Plus Switch issue with Bonjour
Hi, I have a stack of JGS524PE with a JGS524PE Ethernet connected switch. Bonjour protocol works with their Mac computers on their respective switch but the Mac, Printers & NAS aren't able to b...
DaneA
Jan 31, 2016NETGEAR Employee Retired
Hi _Olivier_,
Welcome to the community! :)
I think you will need to configure the JGS524PE switches properly. For the recommended network setup, you may refer on the image below as reference:
Kindly answer the questions below:
a. What is the current firmware version of the JGS524PE switches?
b. Is your router also a NETGEAR device? If yes, what is the model of it?
DaneA
NETGEAR Community Team
- _Olivier_Apr 22, 2016Aspirant
Hi DaneA,
Sorry for the delay of my answer.
Thanks a lot for your answer. I'm afraid I do not know to "set as trunk" as stated in your diagram.
From my understanding I need to flag port "23" and "24" on LAG ID 1 in the LAG config, then enable LAG ID 1. done
But then how do I set as trunk ?
Olivier
- DaneAApr 24, 2016NETGEAR Employee Retired
Hi _Olivier_,
Sorry for the late response.
To set the ports (or LAG ID) as trunk ports, you will just have to set it to "T" (T means tagged) on the ports. Then, click Apply.
DaneA
