bnjroos
Mar 20, 2017Aspirant
Question about redundant m4300-24x24f
Good morning, I am kinda novice in networking and I am struggling into finding the correct material for a drawing I've been sent. Basically I was just sent the following drawing with no more info...
- Mar 22, 2017
Hi bnjroos,
Welcome to the community! :)
I believe the M4300-24x24f is a good choice on setting it as a redundant core layer. Let me share this forum thread and this might give you a better understanding about it. The forum thread talks about the M4300-12X12F, however, its possible to implement it to the M4300-24x24f.
About the proposed network setup, I believe it is possible to implement since the connection from the floor switches going to the core layer switches will be fiber connection.
For the floor switches, I suggest you the GS110TP because it has SFP ports for fiber connection. Kindly check its data sheet here.
DaneA
NETGEAR Community Team
DaneA
Mar 22, 2017NETGEAR Employee Retired
Hi bnjroos,
DaneA
