bnjroos
Mar 20, 2017Aspirant
Question about redundant m4300-24x24f
Good morning, I am kinda novice in networking and I am struggling into finding the correct material for a drawing I've been sent. Basically I was just sent the following drawing with no more info...
- Mar 22, 2017
Hi bnjroos,
Welcome to the community! :)
I believe the M4300-24x24f is a good choice on setting it as a redundant core layer. Let me share this forum thread and this might give you a better understanding about it. The forum thread talks about the M4300-12X12F, however, its possible to implement it to the M4300-24x24f.
About the proposed network setup, I believe it is possible to implement since the connection from the floor switches going to the core layer switches will be fiber connection.
For the floor switches, I suggest you the GS110TP because it has SFP ports for fiber connection. Kindly check its data sheet here.
DaneA
NETGEAR Community Team
