acte28's avatar
acte28
rack or rail kit for m4300-96x
Hello,
I'm searching for a rack or rail mouning kit for a M4300-96X switch. One was not included and I am unable to find a part number or vendor selling a kit for this particular model.
Has anyone had any success with this?
In this manual, it gives instructions on how to install the switch in the rack, however does not like the part number for the rack kit.
https://www.downloads.netgear.com/files/GDC/M4300/M4300-96X_HIG_EN.pdf
Thank you so much for your help!
  • schumaku's avatar
    schumaku
    In my understanding, the M4300-96X package does include the front rack mount brackets and the back rackmount brackets with the support rails.
    Talk to your reseller, or send an email to customer.support@netgear.com
    • acte28's avatar
      acte28
      Thanks for your reply - agreed. We've bought two of these switches and neither has included rails or a mount kit. The installtion manual indicates that mounting them is possible, but does not include any part numbers or kits that must be purchased separately.
      • schumaku's avatar
        schumaku
        Be aware these rails are not slide-out rails - just support to a middle or rear 19" mount.
        LaurentMa Is the assumption correct the rack mount kits is coming with the M4300-96X?
ProSupport for Business
