SaintDanBert
Jul 29, 2015Follower
Re: Bridge Mode or Access Point? What's the difference? Cascade??
I have a structured wire panel where all house CAT6 terminate. From there, they patch to a GS716T managed switch. Do I understand that I would enable IP-passthru on the NVG589. Connect directly to ...
DaneA
Sep 08, 2015NETGEAR Employee Retired
Hi SaintDanBert,
For me, it would be best that you just use your router+wifi box as an Access Point since the NVG589 is a modem-router device. Is your router+wifi box a Netgear device? If yes, what is the model number of it?
Regarding the setup of your NVG589, you might need to contact your ISP for assistance if ever the NVG589 is provided by your ISP.
Is your GS716T and GS108T a v1 or v2 or v3 and so on? What is the current firmware version of each?
About VLAN setup, you may check this link below as reference guide:
http://documentation.netgear.com/gs108t/enu/202-10337-01/GS108T_UM-10-3.html
DaneA
Netgear Community Team
