boe
Nov 14, 2025Luminary
Can't login to M4300 since 12.0.19.15 firmware update
Hello, I just updated two switches M4300-28-POE+ to 12.0.19.15. I go to the IP address of the switch It has the AV UI login and the Main UI Login - I can log into the AV UI login but NOT t...
boe
Found the issue - for some reason when you click on the login it brings you to http://IP-Address:49151/v1/base/cheetah_login.html instead of http://IP-Address:49151/v1/base/cheetah_login.html
