zwavoo
Oct 21, 2016Aspirant
Configuration of RSTP to stop my network frequently Dying.
We have severe problems, I believe with someone in the office crossing network ports, and causing a loop somewhere. This has happened a few times now, and on most occasions, after a few hours Ive man...
zwavoo
Nov 09, 2016Aspirant
Hello,
This afternoon we suffered another outage, and I watched the secondary GSM switch reset itself again (from my syslogs, I think the ROOT did the same, but I wasnt in that room). At the time of the problem, I had only configured the 2 GSM switches as per your recommendation, and had yet to get round to setting all the others to MSTP (They were all on RSTP with priority at 32768). The problem did not seem to last as long this time, after about 30 mins, everything settled down, and I couldnt see anything in the syslogs suggesting a cause of the outage. Slightly irritated by this, I have now connected to all of the LAN switches (not the FS728TP just yet), and set them to MSTP, 32768 priority, enabled broadcast storm, and set it to disable any of the ports at 1% threshold, EXCEPT for the uplink ports, which Ive left the storm control disabled. As of right now, nothing has happened, so Ill put the same settings on the 728TP switches. If Ive understood any of your suggestions, this should then disable any port that starts flooding topolgy updates, except for the uplink ports.
Your thoughts are of course very welcome.
Jedi_Exile
Nov 09, 2016NETGEAR Expert
Broadcast storm won't really cause an outage as you described especially if you network recovered short while later. I suggest pulling the tech support file from both the managed switches and sending it to me so I can take a look.
Also as per my PM reply, The port won't shutdown unless the switch offers such option. On the switches where you have this option and you have selected to shutdown when threshold is met, then yes it will shutdown. Otherwise it will just rate limit it.
Most switches typically do rate limit (not shutdown) when it comes to smart switches. Managed switches will always allow both option types. For smart switches, it varies based on capability of the switch.
- zwavooNov 10, 2016Aspirant
Hello Jedi_Exile. I have now completed the suggestions you made. My network now has the following settings...
All switches (GSM7328S, GS724/48, FS728TP) are set to MSTP, edge switches bridge priority set to 32768, except for ...
Core Switch (building A) which has its BP set to 0, and Building B which is 16384.
All Non Core switches have Storm control set. the GS724/48 switches are set to disable the port if the 3500 threshold is reached, and the FS728TP are set to Rate Limit at 1% since they dont have a port disable option. These options have been set on ALL BUT the last port, which is used to Uplink to the Building Core switch. These have the storm control disabled.
on the FS728TPs, I have the POE ports (1-24) set to FastLink. Ive not YET set this option on all of the LAN switches since I need to check how this might affect users with VMWare/VirtualBox etc on their machines?
I noticed on the CST Port Configs, that there is a "STP Status" option that can be enabled / disabled. How should I have this set?
