ChristISM's avatar
ChristISM
Configure switch in "ring"
Hi,   I would like to know if there is any special configure to configure Netgear switch in "ring", I mean 1x SFP cable from Switch 1 -> Switch 2 -> Switch 3 -> Switch 4 -> then one to Switch 1.  ...
  • JohnRo's avatar
    JohnRo
    Nov 25, 2015
    Hello ChristISM,
    The  GS728TPS' are the only ones that are stackable. I'm thinking you can stack the 3 GS728TPS' and cascade the other 3 switches to them. If you will connect the switches by using thier SFP ports, I am afraid it might cause a loop.
    Thanks,
ProSupport for Business
