Arnaud_D
Dec 20, 2017Aspirant
DHCP Snooping missing on M5300-52G3
Hi, I wanted to set up DHCP snooping, DAI, IP Source Guard on our M5300-52G3. But in the 'Security > Control' Panel I can't found other choice that 'Captive Portal' My M5300 version is '11.0.0....
- Dec 20, 2017
Hi Arnaud_D
It depends on what SDM template that you use.
System > Management > SDM Template Preference- If you use a template for a multicast environment, then you won't have things like DHCP Snooping, DAI, etc.
- If you use a template for an environment not focused around multicast, then you will have other features like DHCP Snooping, DAI and so on.Depends on what you need to use the switch for - set the SDM template accordingly. SDM templates enable you to reallocate system resources to support a different mix of features based on your network requirements.
You can also change it via the CLI. Page 318 onwards.
http://www.downloads.netgear.com/files/GDC/M5300/M5300-M6100-M7100_CLI_v11_20Apr2015.pdf
Cheers!
