MrHumble
Mar 29, 2017Aspirant
Fiber LC/SC patch cables and transceiver for NetGear M4300 and M3300 switches
 Hi,     We have 2 NetGear M4300 (48 ports + 4 10Gb ports) switches in the server room and need to connect to M3300 (48 ports + 4 10Gb ports) on a different floor via the fiber port.  I believe the ex...
- Mar 29, 2017
Happy to help -
I also verified with our cable installer that we have 62.5/125 (OM1) between server room and sub closet that less than 722 feet. So if I use AXM763 transceiver on M4300 and S3300 switches, I could get 10Gb speed by using existing fiber 62.5/125 (OM1) cable? Yes if you use AXM763 10GBASE-LRM SFP+ transceiver on M4300 and S3300 switches, you will get 10Gbps speed by using your existing fiber 62.5/125 µm (OM1) cable.
Should I get the 10Gb LC/SC fiber patch cord 50/125 (OM3- aqua) or just stay with 62.5/125 µm (OM1- orange) LC/SC fiber patch cord? You should stay with 62.5/125 µm (OM1- orange) LC / SC-SC fiber patch cord.
We have another sub closet with S3300 switch and using CAT5 or CAT5E (I will need to verify) Ethernet cable to uplink back to server room M4300 switch Ethernet port. Am I getting 10Gb with this configuration? Provided you can use the 10GBASE-T uplinks on the front on both ends, it is possible to achieve 10Gbps speed using CAT6A for full 100 meter (328 ft) run. Using CAT6, it will be less than half that. I'm sorry to tell you that CAT5/CAT5E isn't capable of 10Gbps speed at all when more than couple feet. You can expect that your uplink back to to server room from your CAT5/CAT5E sub closet will be reduced down to 1Gbps speed by both M4300 and S3300 switches.
LaurentMa
Mar 29, 2017NETGEAR Expert
Happy to help -
MrHumble
Thank you Laurent!
You are the man!!!
