TechAtAnimal
Jun 27, 2017Aspirant
M4300 24x24f unresponsive- amber power light
Hi! We have an m4300x24f managed switch. It is an RMA replacement so was hooked in three weeks ago. When we plugged it into the power it worked great three weeks ago, was able to log in just to make ...
ElaineP
Jun 30, 2017NETGEAR Expert
Hi TechAtAnimal,
Agree with TCan’s suggestion, it sounds like your console configuration is wrong. I only add two pictures to introduce that how to change it.
Due to I cannot see your pictures clearly, so e.g. if use the ipop.exe to check logging, PC port is COM7, please change configuration as below:
Not pay attention to ip addr.
PC change port settings:
NETGEAR Employee
TechAtAnimal
Jun 30, 2017Aspirant
Thank you Tcan and Elaine, I didn't realize Tera Term was resetting itself to a different baud rate every time.
I've gotten actual text now, so I've included a better quality picture of what the error screen I am getting says.
- TCanJun 30, 2017Aspirant
Looks like your firmware is corrupt.
I would wait for a Netgear rep to get back to you as to how to recover it, all my experience is with Cisco kit (I can tell you how to do a recovery on a Cisco switch if that will help!)
I have had a search online and found this docuemnt for recovering the software on a Netgear router but I have no idea if it is the same for a switch (it's very similar to a Cisco recovery). https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
As I said, I would wait for the official answer.
