logicallysynced's avatar
May 06, 2018
M4300 Inter-VLAN routing
Hi there, I've been trying to setup a M4300-8X8F with inter-vlan routing for hours now to no avail. I'm running the latest firmware (12.0.4.8) and have followed all the instructions found in the U...
  • TheEther's avatar
    May 06, 2018
    I can't see the picture (it takes a while for the moderators to approve it for display).
    It's kinda hard to tell where the IP addresses are assigned.  I'm guessing that 192.168.50.254 is assigned to the M4300?  If yes, then are the static routes for the VLAN subnets pointing to 192.168.50.254?
ProSupport for Business
