viknesh
Mar 13, 2018Aspirant
M4300 SFP Port Trunking Issues
Hi Planning to get M4300 switches for pabx implementation for multi campus environment. So incoming trunk line are both PSTN and E1 PRI ISDN. We have few buildings that we need to connect via n...
- Mar 17, 2018
Of course, yes.
schumaku
Mar 15, 2018Guru - Experienced User
... the more confused I am. One one hand, you design a 10 Gb backbone (potentially a little bit a "thin" channel) over fibre. On the other hand, do you expect a two wire connection of an E1 or a POTS ging direct onto the switch to be tunneled? Or are these E1 and POTS on the IP-PABX and the IP-PABXes are to be linked up over the IP network? Assume it's the later one ... depending on the CODEC used fot the IP-PABX interlinks, wild calulating 64kb per POTS and the obvious 2048Mb for the eight E1, this does sum up 25Mb. Perfectly sufficient.
viknesh
Mar 15, 2018Aspirant
Hi
Sorry my fault i should have explained better. My bad, sorry
1. E1 ISDN / PSTN will not connect directly to Netgear switches.
2. Instead E1 ISDN/PSTN will connect to iP Pabx directly. So pabx modules/gateways/slot cards will be connected to Netgear switch via RJ45 cable.
3. The aim is, Pabx to do the signalling while netgear switch to carry that signals.
4. So the link will be established between main building and campus building via fiber cable thru interconnecting netgear switches.
See attached diagram and also pdf file as attached. both convey same thing.
