Harvan
Nov 27, 2015Aspirant
Netgear switch: XS712T
Is it possible to connect 2 XS712T switches using both the fiberports to create a redundant 10GB link between these switches?
msi
Dec 02, 2015Luminary
It should creating be able to by creating a link agreggation with Netgear it's called LAG, you can find more about in the Software Administration Manual for this switch.
Remember that on this switch the 2 SFP+ slots are shared with 2 RJ45 sockets so plugging an optical module and cable in them will disable 2 RJ45 Ports.
Harvan
Dec 07, 2015Aspirant
Thank you very much for your reply but what does this mean?
"It should creating be able to by creating a link agreggation"
