ChristISM
Dec 02, 2015Aspirant
Port Error on GSM7224
Hi, We have a very strange issue with one of our GSM7224. A computer is connected to port #13. It has like 4% received error and no transmit error. Here's the test we did: -We change cable in...
DaneA
Dec 02, 2015NETGEAR Employee Retired
Hi ChristISM,
You mentioned that you have connected a laptop on port 13 and it works normally. It might be possible that the LAN adapter of the PC previously connected to the patch going to the GSM7224 has errors. Kindly try to disable/re-enable the LAN adapter of the PC connected on port 13.
DaneA
NETGEAR Community Team
ChristISM
Computer that was on port 13 has been switch to port #18, and no more error.
I will try to reset or update the driver on this computer, to see if it works, but it's very strange that on another port it works normally with the same computer :(
