bbryan
Jul 18, 2018Tutor
Preferred Router/Switch for VOIP system
I am planning on installing a VOIP system. Office uses cable modem. I will have 6 PC's on CAT5 cable and 6 VOIP telephone units on CAT5 cable. What is the preferred router/switch that should be insta...
DaneA
Jul 19, 2018NETGEAR Employee Retired
Hi @bbryan,
Welcome to the community!
If you plan to connect the PCs directly the VoIP phone, I suggest you the M4100-D12G-POE+ switch which fits your network requirements. Refer to the diagram below:
For more information about the M4100- D12G-PoE+ switch, kindly check the data sheet here.
Be reminded that you cannot directly connect the M4100- D12G-PoE+ switch (or any switch) directly to the modem. You will still need to connect the modem to the WAN port of the router then connect the switch to a LAN port of the router.
The NETGEAR ProSAFE VPN Firewall Router product line has been discontinued last September 2017. Kindly check the announcement here.
Let me share the following articles below for your reference:
Networking Solutions for VoIP Application Notes
DaneA
NETGEAR Community Team
bbryan
Jul 19, 2018Tutor
Thanks for the reply. I intend to connect all pc's and phones directly to router with CAT5 cable.
