yaboy713
Dec 26, 2016Aspirant
Setting up a VLAN
Hello All, I have a Netgear FS728TPv2 and I'm to setup a VLAN to seperate my WiFi guest from my local network. I have attched my network diagram, as well as a picture of what I have done so far. ...
DaneA
Dec 29, 2016NETGEAR Employee Retired
On the FS728TPv2, the ports that should be tagged are ports 1, 20-24. Ports 1 and 24 should be tagged because both are trunk ports with a PVID of 1. Ports 20-23 should be tagged because the Cisco WAP561 access points are connected to it. Access points are VLAN-aware devices. Ports 20-23 should be set with a PVID of 10.
Here are my follow-up questions:
a. Is the Dell Sonic Firewall the main router of the network? Does it support VLANs?
b. If ever the Dell Sonic Firewall is the main router and VLAN 10 is configured on it, are you able to get a valid IP address (172.16.0.x) on the VLAN10 through the FS728TPv2? You may verify this by setting another port on the FS728TPv2 to be a member of VLAN10. For example, set port 19 as member of VLAN10 and it should be untagged with a PVID of 10. Port 19 should be untagged because you will connect a PC to it. A PC is a VLAN-unaware device. Check if the PC will get a 172.16.0.x IP address. Then, check if you are able to access the Cisco WAP561 access points and finally, check if you could access the internet via VLAN10.
DaneA
NETGEAR Community Team
yaboy713
Jan 01, 2017Aspirant
By tagging ports 1, 20-24 being tagged, is that on VLAN1? What about tagging or untagging on VLAN10? On VLAN1, I tagged port 1 and 24 since they are my link ports to the next router, and all others where untagged. On VLAN 10, ports 1 and 24 where tagged and ports 20-23 where untagged and all other ports where blank. On the PVID, 20-23 where labled as 10, the rest where labled 1.
VLAN10 is configured on the router, along with the 172.x ip range.
