krobinson
Oct 16, 2017Tutor
Stacking ports on GS752TPS
I have three GS752TS connected in a stack configuration as below: Questions: 1. Is the bandwidth between the switchs 5Gbps or only 2.5Gbps? 2. Is it possible to use ports 49 and 50 (or any o...
JohnC_V
Oct 17, 2017NETGEAR Employee Retired
Hi krobinson,
It will be depending on the module and cable that you are using to determine the bandwidth of the port. There are some modules that is working on 10G and 1G. You may check under System > Stacking > Advanced > Stack Port Configuration, if port 49 and 50 is possible to be set on Stack or Ethernet.
krobinson
Oct 18, 2017Tutor
The only ports available to change to/from stack are 51 and 52.
Is my stack bandwidth 5Gbs?
