some
Apr 25, 2018Initiate
Throughput Speed
 I am having an issue with through-put speed. We purcahsed our switch back in 2014. The switch has been working great every since. Recently we upgraded our ISP speed to a 300meg by 20meg connection. P...
- Apr 25, 2018A 90 Mbps transfer rate strongly suggests that at least one of the links is running at 100 Mbps. You should check your cables and confirm that the all ports have negotiated to operate at 1 Gbps.
TheEther
Apr 25, 2018Guru
