dgonsi
May 23, 2017Follower
Transceiver sonnet SFP+ SR compatible M4300
Hi, i want to know if this SFP+ Short-Range transceiver: Sonnet G10E-SFP-SR https://www.sonnetstore.com/collections/network-adapters/products/sfpmodule-shortrange is compatible with the Switch: ...
Acorn123
May 24, 2017Aspirant
i suggest you choose this one https://www.cozlink.com/fiber-optic-transceivers-c322-324/product-62843.html
It is cheaper a lot.
Im sure it can be compatible with your switch:Netgear M4300-12X12F.
Best regards,
Acorn
