Quantumn
Sep 29, 2017Aspirant
VLan not VLanning on GS728TP
Have several cameras which I'd like to put on their own vlan. And I have a server that handles those camers, which I'd like on the camera vlan and default vlan. I find that the GS728TP has 3 default v...
- Oct 19, 2017
Here is how it should be configured as shown in the image below provided that all devices are within the same subnet:About port 3 where the camera server is connected on VLAN 4, it should be set as untagged (U) with PVID 4. It should also be set as untagged (U) on VLAN 5 to have communication to the cameras connected to ports 14, 16, 18 and 20.
For ports 14, 16, 18 and 20, it should be set as untagged (U) with PVID = 5. These ports should also be set as untagged (U) on VLAN 4 in order for the camera server to have access to the cameras.
About port 23, I did not know that it is the LAN printer. Port 23 should be on VLAN 4, untagged (U) and PVID = 4.
About port 2, you may set it as a member of VLAN 4 (if ever you want it in VLAN 4) set as untagged (U) with PVID = 4.
You can use the default Voice VLAN for IP phones wherein an IP phone is detected by its OID (Object Identifier) and segment all voice traffic.
About the default Auto-Video VLAN, you can use it applications that run multicast traffic.
DaneA
NETGEAR Community Team
DaneA
Oct 02, 2017NETGEAR Employee Retired
Kindly answer the questions below:
a. What is the network IP address of VLAN 5?
b. Is the camera server and the cameras within the same IP range of VLAN 5?
c. Is the camera server connected directly to the GS728TP?
d. How is everything connected? It would be best if you post a screenshot of your detailed network setup.
About VLAN 1, it is set as the management VLAN by default. You can change the management VLAN to any VLAN ID you want.
About the error message: "VLAN 1 : VLAN was not created by user" - it is a reminder that VLAN 1 cannot be edited.
DaneA
Quantumn
Oct 02, 2017Aspirant
a. The class C is 192.168.111.0/24, same as VLAN4.
b. VLAN5 doesn't seem to have a class C range assigned in the switch, but yes the camera server and cameras are in the same class C, which is also the class C of the rest of the LAN in VLAN4.
c. Yes, connected diectly, as are all cameras.
d. I have a home server, Ubiquiti AP Pro (wifi), printer, and cameras, all connected directly to the GS728TP. Management of the GS is through my laptop, which connected wirelessly through the Ubiquiti.
VLAN1 for management is fine for me. I thought the Ubiquiti should be the only port in the management VLAN.
Somehow I had cleared the ports for the cameras in VLAN1. There is no 'U' or 'T' on those ports, they're blank. I haven't been able to set them back though nor make any other changes to VLAN1.
