JohBo
Jun 14, 2018Aspirant
Request STP with Wireshark
Hi everybody !
I come to put in use my switch M4300 with the protocol STP, when I capture the trames with wireshark, there are a lot of trames STP and I would like to know if it's ok ?
Than...
JohnC_V
Jun 15, 2018NETGEAR Employee Retired
Hi JohBo,
Welcome to our community! :)
Yes, definitely. As long as the STP works, it will provide so much information if you do have redundancy in your connection.
- Aug 31, 2022Retired_Member
