rajkulkarni
Jun 28, 2018Aspirant
Restoring Saved Settings to Netgear Switch
I have been having problems restoring the configuration settings to my Netgear Switch
I performed the following steps:
1. I saved the switch settings (which includes VLANS) by uploading "...
JohnC_V
Jul 02, 2018NETGEAR Employee Retired
Hi rajkulkarni,
Backup configuration or saved settings are uploaded to your PC as text file and not an image file. Image file is for the firmware and maybe it was the backup image that you were trying to use.
In order for you to have a backup of your configuration.
- Go to Maintenance > Upload > HTTP File Upload and select Text Configuration then click Apply button. A window displays to allow you to open the text file on the management system or to save the image or text file to the management system.
For restoring the configuration after resetting it to factory default.
- Go to Maintenance > Upload > HTTP File Download, Select Text Configuration, click the Browse button to locate the file you want to download then click the Apply button.
Here is the reference(page 250 - 253).
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
