robina_80
Oct 21, 2013Aspirant
routing from dhcp server to switch
Hi all, If i were to create on my dhcp server different networks (vlans) how would i route it from the dhcp server to the different vlans on the switch( obviously i will have to create the differe...
fordem
Oct 23, 2013Mentor
robina_80 wrote: Awesome thankyou for your reply, basically in using MS DHCP server and i have 4 network scopes, and im thinking of buying the M4100 D12G and it says it does dhcp relay so Il get the switch to dhcp relay to my dhcp server, or wont that work?
Check the DHCP server - does it support option 82 - the versions I have used (upto 2008) don't - 2012 might.
