robfantini
Jul 20, 2017Aspirant
routing options RIp , OSPF ...
Our network consists of a stack of gsm7352 with lags to three m4100 switches. In addition we have a pfsense firewall with two wan connections . main and backup wan. gsm7352 is the only s...
- Retired_MemberJul 20, 2017
Hi robfantini
Welcome to the community!1. I didn't suggest using dynamic route protocol(RIP/OSPF) in your network, as on the core switch(gsm7352), there is only one default static route, no setting many static routes. Althouth there are many L3 routing VLAN, but they are all using for local VLANs.
2. For VRRP protocol, it's used for Router Redundancy, and it apply in one specific network topology. For detailed info, please refer to link (page280, VRRP).
3. For L2&L3 Multicast, like IGMP Snooping and IGMP/DVMRP/PIM...., these function used in the scenario with multicast stream(such as: VoD service)
Hope it helps!
EricZ
NETGEAR employee
Retired_Member
Jul 20, 2017Hi robfantini
Hope it helps!
EricZ
NETGEAR employee
