fbcsupport
Jun 03, 2018Aspirant
Routing Question
Hello,
I am trying to change routing so that it occurs on our new ProSafe XS748T switch and get it off of the GSM7352Sv2. We have about 20 VLANs or so.
Can someone please inform me the w...
- Jun 04, 2018
Hi fbcsupport,
Welcome to the community! :)
If ever you are referring to VLAN routing, let me share the articles below and use it as reference guide:
VLAN Routing on Smart Switches
VLAN Routing on a NETGEAR Smart Switch
DaneA
NETGEAR Community Team
fbcsupport
Jun 07, 2018Aspirant
Thank you, this has helped a lot to understand the switch!
DaneA
Jun 07, 2018NETGEAR Employee Retired
You're welcome! :)
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
