brunoabc's avatar
brunoabc
S3300 10G uplink port used as normal
Can I use the 10G uplink/stacking copper port as normal port to connect for example a server with a 10Gb interface?
Thank you
  • LaurentMa's avatar
    LaurentMa
    NETGEAR Expert
    Hi brunoabc
    Welcome to the Community!
    Answer is yes. And S3300 Smart Managed Switches come with their four 10G ports preset in "Ethernet mode", so you can do that right out of the box, without any configuration.
    For stacking, two of these 10G ports (copper, or fiber, or combination) can be configured for "Stacking mode" under System/Stacking.
    I hope this helps!
    • brunoabc's avatar
      brunoabc
      Hi, Laurent.
      Thanks for the quick replay.
      Now I can buy a S3300!
      Bruno
ProSupport for Business
