seader025
Mar 14, 2016Tutor
s3300-28x Stacking routed through 10g ports in computer
Hello, I'm looking to try and run the 10 gigabit stacking ports through a 10g port on a computer to conceptually record all the traffic from one switch. Is this possible, and if so, how would I con...
JohnRo
Mar 14, 2016NETGEAR Employee Retired
Hello seader025,
Welcome to the community!
I believe you'll need to set it up as an ethernet port instead of a stacking port. See Advanced Stack-Port Configuration on page 71 of the user manual.
Let us know if you have more questions.
Thanks,
seader025
Mar 15, 2016Tutor
That worked for the configuration, thank you! My next question is, how might I set up the switch so that I can record all traffic coming from the 24 1g rj45 ports? This will be through the 10g stacking port connected to the computer.
- JohnRoMar 15, 2016NETGEAR Employee Retired
Hello seader025,
The best way to monitor and handle your network is by using SNMP (you can jump to page 80 of the user manual). If you have not tried SNMP before you may have to look at its definition and terms (click here and here). It is hard at first, with the terminologies and setup but once it is configured it is a breeze managing your network. :) You already have a management station so next step is to get an SNMP tool (software) which can be found all over the web, there are trial versions which you can test to decide the best one for you.
I hope this helps. Let us know if you have more questions.
Thanks,
