seader025
Mar 14, 2016Tutor
s3300-28x Stacking routed through 10g ports in computer
Hello, I'm looking to try and run the 10 gigabit stacking ports through a 10g port on a computer to conceptually record all the traffic from one switch. Is this possible, and if so, how would I con...
JohnRo
Mar 14, 2016NETGEAR Employee Retired
Hello seader025,
Welcome to the community!
I believe you'll need to set it up as an ethernet port instead of a stacking port. See Advanced Stack-Port Configuration on page 71 of the user manual.
Let us know if you have more questions.
Thanks,
BGold
May 18, 2016Aspirant
So just to be clear....
The 10G ports can be used for a connection of the switch fabric at 10Gbe to a network device (server, NAS, whatever) OR for stacking depending on how the stack option is set on those ports?
I would like to connect a 10G NAS to the switch though one 10Gbe and uplink to a second switch in stack mode to a second switch.
One set to "ethernet" and the other set to "stack"?
