RottenMutt's avatar
RottenMutt
Security Camera Instl on Private Lan using SightHound DVR Software - How do i setup dhcp server
Hi, I'm trying to setup a private LAN for IP Security Cameras in the Class B range (172.16.0.0-172.31.0.0) and am having dificulty getting DHCP to work on the switch.  I can Login to the switch using...
  • RottenMutt's avatar
    RottenMutt
    Jul 07, 2017
    got it to work, subnet of switch and subnet of dhcp pool need to match.  thankyou tech support Daniel.
    i changed my dhcp pool mask to 255.255.254.0
    "network 172.16.0.0 255.255.254.0"
ProSupport for Business
