RottenMutt
Jul 06, 2017Aspirant
Security Camera Instl on Private Lan using SightHound DVR Software - How do i setup dhcp server
Hi, I'm trying to setup a private LAN for IP Security Cameras in the Class B range (172.16.0.0-172.31.0.0) and am having dificulty getting DHCP to work on the switch. I can Login to the switch using...
- Jul 07, 2017
got it to work, subnet of switch and subnet of dhcp pool need to match. thankyou tech support Daniel.
i changed my dhcp pool mask to 255.255.254.0
"network 172.16.0.0 255.255.254.0"
RottenMutt
Can't seem to get the dhcp server to work. No dhcp offers sent out. any ideas?
(M4100-24G-POE+) #show running-config !Current Configuration: ! !System Description "M4100-24G-POE+ ProSafe 24-port Gigabit L2+ Managed Switch with PoE+, 10.0.2.26, B1.0.1.1" !System Software Version "10.0.2.26" !System Up Time "0 days 0 hrs 5 mins 21 secs" !Additional Packages QOS,IPv6 Management,Routing !Current SNTP Synchronized Time: Jul 7 04:25:46 2017 UTC ! vlan database vlan routing 1 1 exit configure sntp server "172.16.0.2" time-range ip name server 172.16.0.1 ip default-gateway 172.16.0.1 line console exit line telnet exit line ssh exit snmp-server sysname "Security Camera Switch" snmp-server location "MB Closet" snmp-server contact "Eric Anderson" ! interface vlan 1 routing ip address 172.16.1.254 255.255.254.0 exit service dhcp ip dhcp excluded-address 172.16.0.1 172.16.0.2 ip dhcp pool "pool_dynamic" network 172.16.0.0 255.255.255.0 netbios-node-type b-node exit exit
RottenMutt
Jul 07, 2017Aspirant
