Retired_Member
Jul 05, 2018setting up a prosafe gs108
I have a prosafe gs108 v-3 switch . When I connect one computer to it , works fine , try an connect the second an get error messages . like no fixed ip and unidentified network
JohnC_V
Jul 06, 2018NETGEAR Employee Retired
Hi wambam,
Welcome to our community! :)
It seems that you are not getting any IP from your DHCP server. What is the IP address that you were getting? May I know if the switch is connected directly to the modem? Please make sure that your switch is connected to the router and not in the modem.
