Mavrina
Sep 29, 2017Aspirant
Prosafe GS108 v3 is not discovered by the utility
My network is as follows
R1 a router modem Netgear D6200 connected to adsl
SW1 switch GS608v3 attached to R1
SW2 switch GS108v3 attached to SW1
SW3 switch GS605v3 attached to SW1
The principal PC is attached to SW2
I have a problem of degrade in the net and so I downloaded the ProSAFE Plus Configuration Utility in order to control the firmware version and the configuration of SW2 (the I will do for the others)
The tool is not discovering any switch on the network
I tried to deactivate the firewall on the PC but it was the same
On the back of the switch there is no MAC and no ping detectes othyer than the router and pc
The monitor of the router shows no devices attached other than the PC
It seems that the switches are completely transparent
The Prosafe Plus was downloaded in the support page for the switch and the new firmware as well, but how can I manege the switch (and perhaps to upgrade the firmware) if it is not recognized by the software?
Furthermore ... I looked for the RESET button as shown on the specs picture .... but in the position (on the right front ) there is a label with AUTO UPLINK
apparently the device is not resettable
thanks for the kind answers
Hi Mavrina,
Welcome to our community!
The GS108 doesn't have any firmware as this is just a plug and play device. GS108E model is the one with the firmware and not the GS108v series. Even if you use a prosafe utility, definitely it will not be detected as you cannot do anything on the switch anymore. You can just reset it by rebooting the switch.
Please check the datasheet here.
- JohnC_VNETGEAR Employee Retired
Hi Mavrina,
- MavrinaAspirantThanks.
Just one clarification
The re is no reset button. ..... in the place where rhere shuld be. (According to the picture.) There is a written AUTO UPLINK
