nigelgourley1's avatar
Nov 09, 2019
Speed difference between copper and optical 10G connections
We have a QNAP server connected optically and then clients connected optically and copper. With the copper clients we have pretty similar read and write speeds to the server - with the optical ones the speed of the read is less than half of the write speed. The switch is very simly set up, no VLANs virtually nothing... Mostly all default. What could we look at to see whats up. The optical cards in the PC's are different makes and all have the same issue and the QNAP goes much faster via the copper clients so it feels like it must be the switch but how?
Thanks
  • schumaku's avatar
    schumaku
    Just one thought: You suspect all switch fiber ports are affected - why should the QNAP (undefined model, undefined 10G interface card) not be affected, too?
    Same makes, but probably same or very similar chipset?
    The fiber connected PC storage systems have the ability to take the full performance advantage of the QNAP and the environment?
    • nigelgourley1's avatar
      nigelgourley1
      The QNAp is optical also.. The thing is that the 10G copper connectivity works much better than the optical.. All the PC are basically the same.. z840 win 10 and all the optical conected ones perform worse than all the copper connected.. There is a few different types of cards in both optical and copper but the optical ones read performance is always much worse than any of the coppers.
      So it feels like the optical/copper cards and the PCs aren;t to blame.
      Typically optically we get 600M upload but less than 200 m download
      Copper we get about 500M both ways..
      NIge
      • schumaku's avatar
        schumaku
        If this would be a switch fiber port issue, the "slow" download to the PCs would be also a slow upload to the QNAP, isn't it?
        That's why I've requested details of the fiber cards on the PCs.
ProSupport for Business
