robfantini
Jan 21, 2018Aspirant
stack and lag troubleshooting
Hello ,
I have 3 m5300's stacked together. One of the switches is normally off as a cold spare. Code version = 10.0.0.53 for both switches.
We use lags to connect to 4 other netgear switches + two proxmox clusters [ 10 nodes] and a nfs system .
Yesterday I tested rebooting the Management Unit [1] in order to make sure fail over worked. It did not. in order to work properly every lagged switch and proxmox node had to be rebooted. Prior to that there were limited / slow connections.
the symptoms were :
1- very slow backups to nfs. what should have taken 10 minutes took 2 hours.
2- network sluggishness
3- un able to connect to some systems.
and more. we use zabbix and had 60 reports of service / connection issues.
Note this thread may take awhile to get to solved as tesitng can only be done off hours - Saturday afternoon and Sunday morning.
Here is an example of a lag we use:
lag 9 goes to a M4100-50-POE prosafe managed switch. firmware version 10.0.2.26
Web page:
hashmode [ for all lags ] = 3
Stp mode Enable
Static mode disable
Link trap disable
(GSM7352Sv2) #show running-config interface lag 9 !Current Configuration: ! interface lag 9 auto-voip protocol-based description 'to mezz switch' set igmp mrouter interface dhcp l2relay mtu 9216 vlan pvid 8 vlan participation auto 1 vlan participation include 8,20,25,40-41,70,80,90,199 vlan tagging 20,25,40-41,70,80,90,199 exit
On the m4100:
(M4100-50-POE) #show running-config interface lag 1 !Current Configuration: ! interface lag 1 auto-voip protocol-based mtu 9216 vlan participation include 8,20,25,40-41,70,80,90,199 vlan tagging 8,20,25,40-41,70,80,90,199 exit
If you have a suggestion to try to solve this, or would like to see more data please respond.
best regards.
- robfantiniAspirant
regarding link trap : " Link Trap - Specify whether you want to have a trap sent when link status changes. The factory default is enable, which will cause the trap to be sent."
Could someone tell me if that should be used in our case? Or tried?
- DaneANETGEAR Employee Retired
Hi robfantini,
Have you tried to disconnect the LAG connections (4 other NETGEAR switches + 2 proxmox clusters [10 nodes] & NFS system) to check if fail over will work fine once you reboot the Management Unit? If not yet, kindly try it and observe.
Also, you can try to disable Link Trap and see if it helps.
About the slow connections, try to configure Storm Control and check if it helps. Kindly read pages 493-496 of the GSM7352Sv2 user manual here.
DaneA
NETGEAR Community Team
DaneA wrote:"Have you tried to disconnect the LAG connections (4 other NETGEAR switches + 2 proxmox clusters [10 nodes] & NFS system) to check if fail over will work fine once you reboot the Management Unit? If not yet, kindly try it and observe."
Just retest that and failover is quick. no issue.
"Also, you can try to disable Link Trap and see if it helps. "
It already is disabled.
"About the slow connections, try to configure Storm Control and check if it helps.
Kindly read pages 493-496 of the GSM7352Sv2 user manual here. "
OK just checked -
Storm control Global Configuration: was alread enabled and
Broadcast Storm Control All was already enabled.
I have a question on Storm Control Interface Configuration:
for ' Broadcast Storm Recovery Mode' Should that be enabled?
I'll do those next. and will test rebooting the master switch on Saturday.
DaneA
Thanks for the feedback.
To isolate, leave Broadcast Storm Recovery Mode as disabled and observe what happens. Then, set the threshold for the Broadcast Storm Recovery Level and try to enable Broadcast Storm Recovery Mode then observe again if it helps.
DaneA
