Pupp3tm4st3r
May 04, 2015Aspirant
Stack Error with 2 GSM7328Sv1
Hi there, in our company we have two GSM7328Sv1 Switches which we want to stack. We have four AX742 modules, two for each switch. When I try to put them in a stack following happens: The stack ...
Nhellie
May 06, 2015Virtuoso
I suggest change the master first and test, you can use an older version but make sure that you are running them on both switches.
