Pupp3tm4st3r
May 04, 2015Aspirant
Stack Error with 2 GSM7328Sv1
Hi there, in our company we have two GSM7328Sv1 Switches which we want to stack. We have four AX742 modules, two for each switch. When I try to put them in a stack following happens: The stack ...
Pupp3tm4st3r
May 07, 2015Aspirant
So, I´ve changed the master and the failure is still there. And then funny thing is, when I make the second switch to master, it won´t be even create a real stack. The console writes "trying to attach another unit" and then both switches will stop operation, no port leds flashing or something like that. Seems that the second switch is faulty...but I can check this on monday when I have 2 other GSM7328Sv1 switches to test.
Will try with another firmware this weekend, lets see what happends.
Thanks for your replies.
Simon
Simon
