Pupp3tm4st3r
May 04, 2015Aspirant
Stack Error with 2 GSM7328Sv1
Hi there, in our company we have two GSM7328Sv1 Switches which we want to stack. We have four AX742 modules, two for each switch. When I try to put them in a stack following happens: The stack ...
Nhellie
May 12, 2015Virtuoso
Is there a way you could test, the non-working stack along with the working ones? I think this is a ways for you to identify which switch is causing the issue. Simply swap out the switches on the working ones with the non-working stack.
